Should I watercool my chipset
I have a ROG maxiums vi extreme mother bored and I'm planing to do a full water cooling loop, I just wanna know if I should get chip set cooled.
I'm thinking about one of the EK-FB ASUS M6E blocks
I will be overclocking (why wouldn't I?)
Long answer, no. It puts out about 10W of heat, iirc.
No. Not worth the effort and $
what chipset? The Northbridge (or what used to be in there)  is on the CPU so if you plan to Watercool the chipset you have to watercool the CPU. :)
...no.. it isn't
what part of the northbridge is actualy on the board this gen of intel board's? please tell me.
rog vi motherboard
