Should I Wait for Ivy Bridge-E
Logan, Wendel.
I was thinking it's time for a new PC, my i5-520M and my other X4 965 are pretty Outdated now with whats new in the market, so I was thinking Haswell, a 4770K but since the prices of Ivy Bridge-E are now here, specially the 4820K even $20-$30 cheaper than the 4770K, it created a hassle in my plans and pushed me to think of waiting to see what happens with it, I was planing 2-Way SLI too, so the Dobule x16 pci-E are also tempting, BUT the z87 is was ahead of x79 when it comes to SATA and certified RAM Speeds and some other stuff that might actually give the x79 a run when it comes to them, and also ofcourse there is a bigger range of mobo's that could be choosen from, so do you any news about any new boards that will be released for Ivy Bridge-E, or if even it will be using x79/2011? or do you think I should just stick to Haswell?
Thanks in Advance!
BTW what I had planned for haswell is:
what is your budget and what do you want to do with your pc
$2000 and I'll be mainly Editing videos and and Photos for my work on three 1080p screens and heavy gaming, like when not editing, i would game for 20 hours a day or so xD
ohh yeah, and the monitors are not included with the budget, I already own them.
im also wondering if i should wait.
2 760 2gb is actually worse for multi monitor than a 770 3gb.
Wait for ivy-e if you really need the extra cores.
You don't need a 1kw power supply.
Litrily a week away from ordering my new machine. Honestly I do not know if I can wait any longer. Been stuck with a failing laptop for 5 months now. Only things I need is a new Monitor, Case, CPU and Mobo as I have everything else, My budget is 1,500 lol. Wish there would be a leak on release date or an anouncment. September is too vague.
actually the 4820K is gonna be 4 Cores with HT.
and I think I'll give it a shot and see my chances with SLI for multi-monitors and, because I can't afford anymore money for a 780 or a titan. so I'll go for two cards and I'll see how it ends up.
you know how computers are "trial and error"
I guess If you have a X79/LGA2011 board you should wait. I think ivy-e will have lots of differences from the sandy-e and its cheaper from what's released and leaked, but z87 is pretty new and has the same architecture and all.
I have come to the conclusion, Get a 4770k and a high end z87 mobo and a good single gpu. Even a 770 is better than dual 760's because there are issues with sli.
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_Titan_SLI/
760's will have similar problems and some games just can not use sli. (Trials Evolution) and will run at next to no frames. Get a 770 or a 7970. From my research, Its the best option. 780 even better.
It is the pcie lanes that really matter and a 780 has only been bottlenecked in a 4x pcie 2.0 slot. By the time pcie 16x 3.0 bottlenecks a card or the cpu just cant handle it, Both a 4770k and a 4820k will become useless. Save the cash and put it into a better gpu.
haswell and Ivy bridge-e are not the same archutecture. Haswell is 22nm 4core and Ivy bridge-e will be a 8 core 32nm with 2 cores physicly disabled.
Hmm, Convincing xD
I'll be cheking that, Thanks.
Ivybridge-E has already been confirmed to only go up to 6-Cores, I wouldv'e been impressed if they made an 8-Core Ivybridge-E CPU.
http://www.tomshardware.com/reviews/core-i7-4960x-ivy-bridge-e-benchmark,3557.html
it will have 4 and 6 cores only, and they will switch to 22nm
You did not read what i said, It will be an 8 core with 2 cores physicly disabled. Like they did with Sandy Bridge-e. It is a 6 core because 2 cores are completly removed from the circuitry.
ivy-e are practically crippled Xeons. It would always be wiser to get the latest and greatest (haswell) since you already are spending a lot. It may last longer. Ivy-e quadcore isn't really justified, if you bought it for more cores then I would've gone that way too.
