So I have the newest version of 64-bit windows 10, but I am using 32-bit Java, should I change to 64-bit Java? Or does it not make any difference. (If I should get 64-bit java could you please link me where to download it?)
Also, am I supposed to uninstall old Java updates? I looked through my installed programs and two javas are there, one is much older than the other, (here they are)
Also one more thing, I use Avast and I used the "Scan for performance issues" option and it came up with some, but I do not have the full version for avast to automatically change these for me. Does anyone know if doing these will actually do anything? Heres a screenshot:
if your playing minecraft with lots of mods and have over 4 gbs of ram i would highly suggest 64bit java. If you are just a casual user just stick with 32bit its easier to install, update, and manage.
