My current GPU:
http://gpuz.techpowerup.com/13/11/08/57.png
Is it worth it to sell this and upgrade to a 780ti? Or SLI another 680, or wait?
And if I should upgrade, do yall know where a good place to sell graphics cards?
Thanks!
My current GPU:
Thanks!
Naw, you're fine. If you're gaming at 1080p, a GTX 680 is still a beast.
Seconded, the GTX 680 is a beast, If you decide to SLI it you should be able to pull off 1440p at 60fps, 120 frames will be a cakewalk on 1080p.
I game at 1920x1200 and might want 2 more of the same monitor.
It should be okay, you'll have to lower your settings, but you can still play at that resolution at medium-high at really good frame rates.
Just oc that mutta to the max. Still not getting the performance you want? Sell it and get a second hand gtx 780 or a non reference 290. No point in splurging for a 780 ti in my humble opinion.
Edit: overclock.net is one of the largest pc enthousiast forums and has a market place. Don't know if you are required to sell it over there without a minimum reputation requirement though. Or try and sell it on the forums here.
Where do you live?
Thanks, I live in Atlanta, Georgia
Wait for non-reference R9-290X, maybe?
That is a nice card you have there. If you are going for 3 screens then I would suggest another. I myself am waiting for non-reference 290. I don't want to spend over 500.00 mark on a video card that will be 300.00 in a year.
