So i want to upgade my pc, but is it necessary?
I got an i7-2600 on 4.10 Ghz, with a Gigabyte GA-Z68X-UD5-B3.
I want to upgrade to a Maximus VI Formula:
http://www.asus.com/Motherboards/MAXIMUS_VI_FORMULA/
And i7-4770k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116901
You could but depending on what you are doing you would be better off getting another 670 and doing sli if you are looking for more fps. If you are doing cpu heavy things then if you really need more speed go for it.
Thanks mate, all i needed to know :D
For gaming, there is little difference between the 2nd (yours), 3rd, and 4th Intel generations of processor.
