I currently have a Corsair CX 430M.
If I am overclocking my fx 6300 to lets say 4.0-4.5 ghz should I change the PSU? I can sell this particular psu to my friend if I need another one.
Depends on your choice of GPU. You would be fine using a middle-tier GPU like a 270x. Higher-end cards might be a bit more troublesome. Particularly if you want to overclock and stress the hardware.
Depends what else is in the machine mate. GPU?
You do realise that when a cpu is overclocked (and chances are needing extra voltage) the power consumption rises exponentially yeah.. The cx430's are great little units but there is no point in running it balls to the wall. If you have a mid range gpu in the system then I would be looking at getting another unit just to have some headroom - a good 550w from xfx or something perhaps.
I am upgrading from a fm2 socket to an am3+ socket. I have a HD 7850 and that is running at the stock clock.
I am upgrading from a fm2 socket to an am3+ socket. I have a HD 7850 and that is running at the stock clock. I can sell this psu for like $30 or so to my friend who is actually buying my fm2 rig right now.
Really depends on the rest of the system, probably not though.
I have a friend who's running an athlon x4 760k which gobbles around the same amount of power as a FX 6300, he's on a CX 430M as well. No issues for him so far.
Overclocking the FX 6300 makes it take some extra power but the CX 430M can probably handle it. Again, depends on the rest of the system.
FX6300 and 7850 should run fine on a CX430. It's always in your interest to get the best quality PSU you can, but you're not under any pressure to do so.
I'd estimate that your usage won't be much more than 350W, and that's including fans, HDDs, et cetera.
This is my current specs
Cpu and cooler = A8-5600k OC 4.3 ghz with a Xigmatek Gaia cooler
GPU: HIS Radeon HD 7850
Motherboard: ASRock FM2A85X Extreme4-M
PSU: CORSAIR CX430M
RAM: G-Skill Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000)
Computer Case: Coolermaster N200 Case
1 128gb Apple SSD and 1 500gb Seagate
ok thanks.
Cool, a 7850, uses bugger all juice. Thats good news. CX430 ftw.
430W is totaly fine ☺ you can even power a more higherend gpu on that like a 270X. For a 280X its tight but still should be capable, because you system is not constantly under full load. a Msi 280X uses arround 250W on full load. with the rest fo the hardware set you will maybe suck arround 380W. only the sapphire Toxic´s are powerhogs.
so the r9 270x and 280x is the successor to the 7850 and 7870 right? Thanks for the power consumption details. Saves me money that I will now put into my new case for this upgrade i am doing.
well the 270X is a 7870GHZ edition with a new sticker. a 280X is a 7970GHZ with a new sticker.
