Hi im really in to arma 3, and play it alot.Currently i want to improve my sight from 1000 m to 2000m.i like using the 75x scope and mill dot aiming it feels amazingly satisfying to kill that way. Any way to the point, i have a evga gtx 670 which has a problem with heat, i dont like going past 80 in heat and it has trouble going to 2000m on arma on a multiplayer game.
do you guys think i should upgrade my card, and to what card?(im not a fan boy so i dont care if its amd or niv)or should i upgrade to water cooling and create a loop and push the over clocking (it would be a plus if it would reduce idle nosie)i havent tried water cooling yet so any help would be appreciated.
thank you guys.
