hey guys i have GTX 760 n now i'm thinking to upgrade it to R9-280X (Not enough Money for 290). I play Games at 1080p Ultra settings (Single Monitor) no Video editing stuff just Gaming. also can GTX 760 play all the Games released within next 1/2 year on Ultra Settings.
well if you have an extra pci-express slot and enough room in your case i would buy a second 760,
but otherwise the 280x is a great card.
I think the 760 meets your needs. It should play almost all games on ultra at 1080p.
I just got my GTX 760 and it does play everything I have tested on it on the absolute highest settings and buttery smooth fps at 1080p until I ran out of really demanding games to test on it. It's a fantastic card for the money.
I wouldn't invest in anything more unless you are planning to go higher than 1080p in the near future.
I have a 280x and i can easily max out any game 1080p 60 FPS (except for BF4 but after testing some things and looking at the built in CPU/GPU chart i think my 4670k is causing a issue so i cant achieve 60 FPS all the time).
A 280x is a tier above a 760 but i think it would be a pointless upgrade. the 760 came out like when? june? july? its still pretty new.
Now maybe if you saved up a bit more and got a aftermarket 290x it would justify a upgrade
I would save my money to get a 290
thnxx guys it was really helpful.
