Should I Update my CPU and Mobo or GPU first?
I currently have an fx-4100 and I am thinking about either getting an i5-4670K with an MSI motherboard or a new GPU- 780 Ti or 780. I'm just looking for some opinions.
gpu, u can feel the performance jump sooner -just my opinion
While the FX-4100 isn't the best it is perfectly fine for gaming. Most games are GPU dependent so you'd see more of an increase in performance grabbing a new GPU. What GPU are you currently running?
What resolution is your monitor? A 780 Ti or 780? Those cards are quite costly and can be complete overkill, especially for 1080p resolution. Depending on your budget I'd grab something a bit cheaper. You can find nice HD 7870 GHz Editions for $150....
I am running a 7850, but I am going to buy a new 1440p monitor and I am planning to buy a g-sync monitor when it comes out.
