[img]http://i38.tinypic.com/2lmm7hj.jpg[/img]
is what i had there it was with the case but i changed it and added 2 120mm fans.
[img]http://i34.tinypic.com/358nhjn.jpg[/img]
i think the normal 1 looked better what you think?
or should i buy 4 small fans and put it there like the stacker 830 ?
Logan
#2
does the update cool better? seems like it might... looks good too.
Ill need to check later. my AC is off im about to go to bed i had to re wire some fans cuz i wasnt getting power to some :(
JMFH
#4
two is better than one (in this case it applies)
maybe you should have like 10 fans on the side panel. that would be cool. literally
21DD23
#6
one fan would defintely look better, but i do like how the two fans are alot brighter
