I've been seeing used 7950s going for a variety of prices on ebay, usually over $300.
My card is in excellent condition, I have all the original accessories, it was never used for mining, and I occasionally ran it OC'd: stable at 1150/1500 with no voltage increase.
Of course, if I do sell it, I'd need to replace it with something. I currently have a 650w PSU (Corsair tx650) and my resolution is 1920x1080
So should I sell it, or keep it? I'm also open to more suggestions of what to replace it with it I do sell it, I have no preference with nVidia vs AMD.
Truthfully, the 7950 gives performance comparable to the GTX 770, and it is capable of beating it. However, the 770 is generally considered a step-up.
I personally view the crossfire setup as a step backwards. This is because crossfire setups have problems, some games do not use multi-GPU configurations at all. It requires a higher power draw. It's a high price to pay to attain a higher FPS in some games, but not others.
I suppose you could grab the 770. But with an AMD card, you can use it for mining, it's better for modding games like Skyrim, and you're securing the use of Mantle - we don't know for certain whether Nvidia will adopt Mantle or create their own solution. So in Battlefield 4 and other supported games, an overclocked 7950 would certainly beat an overclocked 770.
Good question. Firstly, I do not think there's any reason to upgrade the 7950. I just wanted to state that.
You could purchase a second 7950, and at a reasonable price, I think it would be worthwhile. Again, it won't be appropriate for all games. Not all games run well on dual GPUs.
Depends on your resolution, and it depends on your needs and wants. If you're not satisfied with the performance of your 7950, I suppose you have every reason to upgrade. At 1080p, there is a substantial performance difference between the 780 (or similar performing card) and the 7950. But that difference is diminished at higher resolutions.
I think you would have to view performance benchmarks of the 780 or R9 290 and determine if it is worthwhile. I can't tell you. I think the performance and capability of the 7950 is truly amazing.
Well, outside of Skyrim w/ mods, I'm quite pleased with my current performance. I get 30 fps or more on most games with max settings, and for the most part it's more along the lines of 40 with the exception of Crysis 3 and I think Metro: LL. I have been toying with the idea of moving up to a 1440p monitor, but I have no idea if that will happen anywhere in the near future.
Thanks for your replies though! I think I'll just stick with my 7950 for now, and only upgrade if I move to 1440p or if I still have it in several years.
The 7950 really is an amazing card in terms of performance, I only wish I waited and purchased one when they were going for under $200.
I get some nasty frame time variance on my 7970's in CrossfireX while playing Skyrim. Causes stuttering even though there is a solid 60 FPS. Often times I have to play with just one card and lower fps.
I think sticking with what you've got now and waiting until either your performance with newer games is unbearable, price of GPU's drop, or if you've got fat stacks to spend.
I would have a hard time spending the money on what cards are going for now days. I managed to get mine right before the R-Series AMD cards came out for pretty cheap.
7950 is a capable card at 1440p. That's my point, it just seems to be a really good solution. Skyrim mods hurting your frame rate could be somewhat dependent on the CPU. The 7950 gives comparable performance to the 780 in modded Skyrim. Skyrim mods seems to prefer AMD drivers, it's just how it happens to be. That's why I cannot stress enough, you really ought to have some specific use or benefit that would require the upgrade - and at this time I don't see it.
