My Gigabyte 970 is making coil noise when under load. I've talked to both gigabyte and the retailer, but I have not been able to get a straight answer on whether it is considered a defect or not (I've been approved for an exchange because it is within 30 days of purchase).
I just wanted to get some advise here to see if it is considered a defect or if it could mean/cause damage to the card. I ultimately want to know if it is worth all of the trouble of an RMA.
(The card performs well. I've been able to get it to 1500mhz stable.)
I see, i'm sorry for the late reply. If the coil whine is always present and it's something that's annoying enough to you personally to notice then you should RMA it.
Right click on the top left hand corner on gpu-z and check its asic rating >80% its a golden card so keep it and deal with a bit of whine. Otherwise return it while you can.
Coil whine usually dosent fall under faulty. My 780 had coil while when I first got it but over a month of usage the card broke in and the coil while stopped.
