Should i get 16GB Corsair 4x4 GB 1600mhz our 8GB Corsair 2x4 GB 2300 mhz? They are almost the same price where i live.
well unless you need 16 alot id just go with the 8, but your mobo may not work with those speeds and you dont really need it.
there is no real reason to get ram over 1600MHZ since it makes very little or no difference
also you will probably never use over 8GB, so the extra ram you get will just be unused
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231589&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
may be those 2x8gb then you can add more ram later!?
Whatever you want to do; overclock or just want more memory.
