I need a new monitor, and i'm unsure if i should just get a normal 1920 x 1080 monitor, or get a 2560 x 1080 UltraWide monitor, my only worry is that some games won't run in that resolution, I've never really been a pc gamer and i'm only getting my first now (unless you count a late 2006 iMac that I used to play WoW & LoL on) So i don't know if a resolution like that will work, I'm just confused...
If i bought it, would gaming on it be okay, or should a UltraWide be used for productivity based things?
Unless it's the free-sync ultra wide you're better off with a 1440p display for the same price, really ultra wides in general have no place in the world when you can get more vertical pixels for the same price
As far as productivity goes though you could get this 1200p IPS display which gives you more vertical pixels if you ever run it in portrait mode, 1080p doesn't have enough to handle portrait mode web browsing
really I'd go 16:10 over 21:9 if the pricing is the same, but I do some photoshop and video editing work sometimes, more vertical space is always welcome
Alright, Thank you. You helped clear up some of the confusion i was having (although there's still plenty there). I'm just more or less unsure if since i plan on doing things that require a lot of space, and i don't currently have any room for 2 monitors. If an ultrawide would be okay for gaming, of i should just work with one 16:10 monitor instead
Unless ultrawide is much cheaper than a 1440p, you should get 1440p instead. I'd get 2560x1080 over 1920x1200 though. Ultrawide allows you to have two windows side by side, 1920 pixels is not wide enough for that.
If you are considering an ultra-wide monitor like the LG 29UM67P that I own, you have to ask yourself how much you watch 1080p Bluray movies. If the answer to the question is a lot, then you need to get an ultra-wide with freesync if you are also considering gaming on it.
I'd prefer a 16:10 screen, it's just that i only really have the space for 1 monitor, rather than a double or triple display setup that i'd like. so I just thought that maybe buying an ultrawide, i'd have more space for now than just a single 16:10 screen, although i might have to reconsider my opinion and take yours instead
You could always just get a monitor arm and have one display sit vertically over another to save desk space, then just get like 2 normal 1080p IPS displays
it really just comes down to weather you want more horizontal space or vertical space
That's a good idea... Although i'd much rather a monitor off to the side. I might just end up getting a 1080p display and waiting for a new desk/more space to add another monitor.
When it comes to just simply gaming, what specs should i be looking for in a monitor? I'm unsure about all the responce times and refresh rates etc. Mind helping me (once again) please :)
Pretty much every monitor is going to 60hz, response time doesn't matter much for normal games, all you really want is an IPS display for better color and viewing angles
Thank you, i've got 3 monitor's that i'm looking at, I just have to decide which one, i believe all of the specs are similar. at least the important one's
I just brought a new monitor Benq 24 144hz, was going to go with a 34 inch 2560 x 1440 ultrawide but the prices are just absurd here in Australia. I'll wait until the price goes down on them.
