I’m planning on a FreeNAS build and I want a motherboard with at least 12 sata ports.
The CPU that I’d like to use is E5-1620 v4
So this makes my options of supermicro motherboards to be one of these:
The maximum number of sata ports in all of them is 10 ports. So I’m going to need a HBA card.
But I noticed that X10SRH-CF has SAS3 on-board.
X10SRH-CF
Is it a good option? If so, Will I be able or need to flash it to IT mode?
Will the mini-sas to sata cables on amazon work with it?
Thanks
