Should i build my own pc or get it from cyberpower?
the thing with cyberpower is that one build gives you windows for free, that means i am saving 100$ or so, the prices are about the same and i dont have to build my own pc and i can change anything after i get my pc, or i order each part and build it my self
Build your own! I could rant all day on cyberpower's business practices. Also, being able to work with hardware is a usefull skill to have, and building a PC is fun! Tell us your budget and we will create a build for you.
Trust me, the Windows copy isn't "free". You overpay for every single part that is in that build. In the end, them giving u the $100 OS is just cutting their profit a bit to convince you. Give me your budget and I can make you a build.
get alienware its proer
@lienw@re is awesome cus liek i think they giv u windoez 8 n it luks nice
^ Lol.
Build your own. *Y'aaaaaarrh* your OS
Why use Windows when Linux is compatible with Steam and Spotify? I reccomend Ubuntu 12.10, a disk is 5 bucks.
i am searching for a pc from 1000 to 1050$
the current things i am thinking of getting are these:
motherboard: asus p8z77v-lx
gpu: nvidia gtx660
cpu: corei5 3570k
ssd: intel 330 120gb
no hdd
ram: 8gb of g skills 1600mhz, they are 4gbx2
for cpu cooler an hyper 212 evo
and for powersupply a corsair CX600
and windows 7 home premium 64bit
lol saying you should get linux because it's compatible with steam and spotify is like saying you should buy a tractor trailer because it can haul things.
