Should I avoid the audio in/out ports?
KVM Model:
USB-C KVM Switch v3 (with USB Power Delivery / 135watts)
5GB u2 mode
Problem:
I’ve seen Wendell note that he’s not thrilled with the analog ports and that potentially a cheap DAC there might be an improvement. I was hoping to dig into that a bit more.
Context
I’ve got 2 Macbooks connected to the KVM, both with thunderbolt cables, both running Sonoma
  1. M1 2020 Macbook Air (personal)
  2. M1 2021 Macbook Pro (Work)
On the other end I’ve got a pair of KEF LSX II (KEF LSX II | Wireless Speaker System | KEF USA)
Question
Given this setup, would using the 3.5mm ports be a degradation compared to USBC audio? I have found that the KEFs tend to have the occasional issue with the macbooks where I need to reconnect the USBC if the MBP attempts to use them prior to them starting up. the 3.5mm connection doesn’t have that issue. However, I’d probably prefer that issue to degraded sound.
Does the KVM use an internal DAC or shell out to the active computer? Are the ports themselves the issue?
Thanks
I don’t know all of the nuances of aux-related issues, but I’m prettyyy sure it is the nature of the ports themselves. The easiest and cheapest fix we always recommend doing is buying a ground loop noise isolator like this one:
Okee Dokie.
Thanks!
Welcome! Let me know how that works for ya :slight_smile:
This is working well, thanks!
