Should 3000MHz CL 15 RAM work nicely in 3000MHz CL16?
I own a Corsair Vengence 3000MHz CL16 Kit (CMR16GX4M2D3000C16).
I’m looking into buying a Corsair Vengence 3000MHz CL15 kit (cos it’s a few bucks cheaper on Amazon) (CMR16GX4M2C3000C15).
Would the latter work fine at same freq and higher CAS Latency? I plan to use them both together.
How would XMP deal with two different profiles?
Do not mix and match memory willy-nilly.
In theory, the CL15 kit should work at CL16 just fine. The other timings and make of the memody modules does come into play too.
Worst case: RAM runs 2133MHz at muddy timings.
Best case: Both kits run at 16-20-20-38 (instead of the nice tight 15-17-17-35 of the new kit)
Well, I’m already running at muddy timings because of my older G.Skill Aegis kit. All I want is to run at 16-20-20-38.
