i'm looking for a case that can house a 650, corsair i60 and an ATX motherboard.
extra challange, it musn't be over 430mm in hight.
any ideas?
any ideas?
bump?
Possibly the Fractal Design Node 605?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352028
(An In-Depth Overview: https://www.youtube.com/watch?v=kWFsKR1CTVQ)
should have mentioned it,the case musn't be wider than its hight
Aerocool DS, Bitfenix Prodigy, Xigmatek Aquila, Fractal Desgin Arc mini and Define mini and A ton of Lian-Li cases fit the bill.
Lian Li PC-A05FNB - 385mm
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112331
Corsair 200r - 430mm
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139018
Cooler Master N300 - 426mm (if you can find it in stock)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119279
None of those are ATX, minus the vague Lian-Li suggestion.
ah yes missed the atx part :)
