I'm looking for a monitor to use with my other 22" 1080p monitor. I don't really have a price range or budget but the lowest price in the UK would be best. I can wait for deals if they come anytime soon.
Also, are there any desk monitor arms anyone recommends for these?
Thanks
It seems there isnt any. Most of them are 27inch and up or 18.4inch and down.
1440P on 22" will kill your eyeballs. Plus it won't look right with a 1080p monitor if you use them side by side. Despite having the same screen size the 1440P monitor will be able to fit more stuff because of the higher resolution. Not to mention most are 27"
OK thanks, any cheap 1440p monitors you recommend then? I'd go for the X-Star DP2710 but I'm worried about the customs charges for importing to the UK from South Korea....
