Is there any sort of size chart for the new shirts? I'd like to get something, and would rather not get it in the wrong size.
Yeah, I also would like a size chart, I order a large one, but I usually have medium so its going to fit, but it might even be to big!
I know the old shirts were printed on American Apparel fine jersey shirts... not sure what the new ones are printed on though. Would be a good idea to put up some shirt information in the store, that way even if there isn't a size chart on site, people can look it up or compare to shirts of the same brand they already own.
They're Next Level Apparel shirts. They fit a little thin but probably just as long.
http://www.promocorner.com/catalogs/NextLevel/Next2014Catalog/#/20/
do you mean shirts or T shirts?
for shirts. just measure the size of your neck and order accordingly. the rest of the shirt will be standardised or is something you can get tailored more or less.
if you are thin/athletic choose a slim cut, otherwise regular.
Seems pretty tiny based on their 3600 S/S crew size chart. Unless they have some really funky way of measuring, their sizes are way off from others I see/normally buy in brick and mortar stores. I mean their XXXL is much smaller than a men's large based on that chart.
Only see T-shirts on the store, and also see no option for "slim cut" or "regular."
The large is large. Actually, it might even be a little bit bigger than a normal large, especially since the fabric is a little bit stretchy.
http://www.nextlevelapparel.com/45/resources.htm
They don't have a variety of models and sizes, though the scale should be enough to tell. I'm 6'3", but I have long legs and probably could have gotten away with a medium.
didn't realise this was tek syndicate store related. sorry. ignore my post. lol.
Thanks for the help, here's to hoping large works out for me.
