Sfx power supply recommendations
Looking to transfere my i7 system into a Lian Li Tu100b and as im going to college next year, but i am unable to find a sold PSU that will fit that isnt over 70$. My system will be the following
CPU- i7 4770k
GPU- waiting to upgrade to either a r9 290 or gtx 880 depending on the price
HDD- if i can fit them 2 3.5'' 7200 rpm drives
SSD- 1 120gb & 1 240gb
RAM-16gb (2x8gb dimms) patriot viper 3
optical drive- maybe a slim blu ray if I find a deal on it other wise a dvd reader writer.
Also will i be able to mount a h60 in that case?
you are a bit boned, Cause Silverstone is the Only Company that makes quality SFX PSU's you don't really have much option in terms of choices for SFX PSU's. as of right now there is only a 450w PSU out, Silverstone has a 600w SFX coming sometime in Q1 or Q2 2015. but that's a long way. and for the record an R9-290 and GTX 780 will NOT fit in that case. the case is 7 inches in Length. the most powerful you can put in there is an R9-285 that just got released a couple of days ago. Sapphire has a 5 inch model of the card. and so far the R9-285 is faster than the 760 in most benchmarks, sitting in-between a R9-280 and 290 in terms of performance.
But here is the best you can get for the SFX right now
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256084&cm_re=Silverstone_SFX-_-17-256-084-_-Product
alright.
yeah that's about it ... slim pickins
