Sexy OP workstation build... MB bootable RAID 0...? Am I crazy?
I’m building a new TR Pro workstation and am wondering if it’s worth it to go with two 1TB 980 Pro NVMe drives in RAID 0 for a boot drive? I saw Wendell’s video on MB RAID and I’m just not sure anymore…
I’m using the workstation primarily for doing post processing on extremely large point cloud data sets and of course, some gaming while I wait for the processing algorithm’s to finish.
Haven’t built a PC in a few years… Not gonna lie, rather nervous about putting so many fish sticks worth of gear together!
The Build:
Supermicro M12SWA-TF
Threadripper Pro 3975wx
8 x 64GB DDR4 3200 ECC RDIMM
2 x 2TB 980 Pro NVMe drives for main storage.
Nvidia RTX A6000 GPU
SSDs are cheap (especially in the context of your build), I’d be inclined to get a SATA ssd boot drive. These are still plenty quick for loading windows and apps from - or you could put an m.2 to PCIe adapter in if you wanted.
You might also want to do some testing with those drives/motherboard to see if Raid 0 actually provides much performance improvement - those drives are so quick already that it’s as likely that some other kind of bottleneck will be introduced.
In my testing with SATA raid on AMD SSDs ran rather slower on the AMD raid driver than they did using the generic AHCI driver - so you might want to run a software raid instead of the AMD one in any case.
Having a separate boot drive will let you test the options and slightly reduce the chance of you losing your data (I hope you are backing up if you are using raid 0!)
You can always add some low capacity NVMe SSD for 50 bucks if you want a bootable drive without making compromises on your raid. Or plug in some old drive unless you are obsessed with booting. Low capacity SSDs (2.5" and NVMe) got really affordable.
You have a clear answer… what’s not to be clear about? LOL I think he was pretty sure in his conclusion.
Fair Enough
So what would be a better option to gain increased throughput and still keep the OS, Applications and Scan data on RAID? Seems to me like just running off a single 980 Pro would become the bottleneck. Am I wrong?
I would watch this Optane video and then think about another strategy - single NvME as your boot volume and a P5800X as a Level 2 cache using PrimoCache.
The problem even with RAID as your boot vol is latency. Your boot vol isn’t really about sustained transfers but instead tons of tiny requests. @wendell can chime in if he has time.
I went with this build after chatting with @wendell and my system doesn’t wait for anything. I would strongly consider this option. There are P5800X units in stock if you know where to look! :innocent:
I’m running a 3975WX on the Gigabyte board. I even allocated a block of RAM to act as my Level 1 cache in PrimoCache.
Ooof!!!
So many fishsticks!!!
But these ones are delicious! Not to be missed. Insane tech.
What’s another $9k on top of an already $18k system.
Perhaps that will have to wait to be a xmas present to myself… lol
Eh? USD$1,400 for the 400GB is all you need.
Build a RAID storage with cheap SATA and have PrimoCache it too! Set the deferred write to say 10 seconds if you’re confident and you have a UPS on your system. I’ve done that with my Promise RAID arrays using TB3 and my oh my are they insanely fast.
Canadian options are more limited… Was only showing the 1.6 TB version on newegg.
I am Canadian! DM me.
Will this MOBO even support BIOS RAID? From the specs…
  • M.2 Interface: 4 PCI-E 4.0 x4 (Software RAID 0,1,5,10)
What kind of cable connects from the motherboard to the P5800X? Does it connect into one of the motherboard’s NVMe sockets, or one of the slimSAS ports?
Does PrimoCache give you any sort of cache utilization and hit rates? Any numbers you can share?
Not a cable. You mount it on a AIC. Just drop the P5800X into one of these:
I like the ones by StarTech but there are other brands that work. If you watch the chat between @wendell and Allyn Malventano from Intel on Patreon you’ll see that’s how they mount them in the vid too. You do support @wendell by being a Patreon, right? :thinking:
It certainly does…
Moi… share? Teehee… of course I can share. On my Win 10 Pro system, 3975WX with 256GB RAM on a Gigabyte WRX80 MOBO. C is the boot vol and D is my Promise RAID array using TB3… yes, it’ll even work with external RAID arrays and my gosh, is it zippy…
Any questions?
Ah, a SFF-8639 connector. (Amazing how they can’t list that on the product description.)
Rather than waste a x16 PCIe 4.0 slot for a x4 device, couldn’t you use a Slim SAS SFF-8654 4i Straight to SFF-8639 U.2 Cable (e.g. sff-8654-4i-to-sff-8639) to plug the drive into one of the three SlimSAS ports on your WRX80-SU8-IPMI motherboard?
Those PrimoCache number look interesting. I think I’ll grab a copy and give it a run with just Level 1 cache (as I have good power and plenty of RAM), and then give an Optane add a think (for some nice persistent cache across boots.)
I talked to Intel about that actually and they said it’s not intended to be used in that fashion but rather mounted directly on a backplane in a server. Why they’d ignore the complete market segment is classic Intel at this point presumably.
Ooooh… sassy… is there a Super Micro version of that cable? I’m not familiar with Micro SATA Cables as a manufacturer / vendor.
Often these kinds of cables are very not pcie4 without redrivers and all sorts of crazy.
Looking at the cable gives me a rash.
