Settings for Fallout 4
What would be good setting to have Fallout 4 on both in game and in the AMD radeon settings menu for this set up http://pcpartpicker.com/user/SoujiDesigns/saved/PxJJ7P to get it to run at a stable 60 FPS without overclocking? Sorta newish to tweaking settings and could use some help. Can't seem to get the game running at a stable frame rate.
I think to get any significant difference you are going to have to get a couple of mods.
I HIGHLY recommend backing up your savegame before doing anything though.
Fallout 4 Configuration Tool will give you access to a lot of settings. For AMD you'll want to disable Godrays.
Shadow Boost should net you some considerable gains.
Thanks I will try that out and see if it helps
