Server Build - Looking for Advice (ML/AI)
Hi everyone. I’m looking at either building a server with AMD CPUs or buying a used Dell R750XA. There appears to be a wealth of knowledge on these forums, so I would appreciate any advice. I’m hoping to price out a build vs. buying used. I’m not interested in using a cloud service/renting off-site GPUs.
To follow the general guidelines of the Build a PC forum:
-Looking to spend less than $8K (excluding GPUs)
-US-based
-No preference for retailer
-Peripherals covered
-Server will be used only for development, training/fine-tuning, inference, and local hosting, possibly giving myself remote access to hosted models
-I don’t think I want to get into overclocking
-Cooling - I’m open to options
-Operating system will be a Linux distro - high probability it will be running on Arch; I use ProxMox to manage the Servers/VMs
Requirements:
-Will have to support (4) PNY NVIDIA A6000s. My initial plan is to NVLINK each pair. I have two in-hand, two on the way.
-PCIE Gen 4.0 +
-AMD CPU
-Looking to procure the components fairly quickly
I’m interested in hearing all the components you would recommend for a build like this, from the motherboard to the case to the cables.
Thank you!
Here is an option I’ve cobbled together:
-Motherboard: Asrock Rack ROMED8-2T/BCM ATX
-CPU: AMD Epyc 7552
-SSDs: 2x Samsung 990 Pro 4TB
-Cooler: Not sure yet, but the Supermicro OLGA4094 4U fits the 7xx2 series CPU
-PSU: Silverstone Hela 2050 Platinum
-Case: Silverstone RM43-320-RS 4U
-HDDs: Not sure yet, but I’ll estimate $1k to start
-RAM: Not sure what’s compatible, but I’ll estimate $1k to start
I’m estimating these specs to cost around $7K. I don’t know whether 4U is overkill. Thanks again for any insight.
Welcome to the L1T forums.
For AI and ML, it is a bit tricky. You see, the only reason you need GPU power is for training a ML model, and there you also need a metric ton of data to train on. If you only plan to run the model, you only need a fraction of the training setup.
An RTX 4060 can with ease run a stripped down version of most AI models and retain 99% of the results, the only limiting factor here is the amount of VRAM. Sure, an A6000 will run circles around a 4060 by about a factor of 2.5x or so and can fit much larger AI models. Here is the thing though, once an AI model has been trained, the model can easily be compressed and achieve a 99% equal accuracy at a fraction of the VRAM. This is not any less different from your average Youtube 4k video stream vs two hours of RAW 4k footage. While it makes sense to store the original model somewhere, the compressed model is by most accounts good enough and can also be run on a $300 GPU.
Your build looks pretty solid otherwise, but before you pull the trigger on something expensive like this I want you to make sure you actually need this. Are you actively doing AI research? Otherwise you are buying the equivalent of a Formula 1 car in order to do grocery shopping. It is far easier and cheaper to rent the compute from Amazon if you are just dabbling in it.
Also, HDDs doesn’t make sense at all in a build like this. HDDs are now too big of a bottleneck and state of the art AI research has moved on to all flash exclusively.
would be good to put a pc part picker list or equivalent in place?
your gpu is critical…
things to consider linux or windows build… in relation to graphics from among nvidia vs amd vs intel gpu… software, sdk and drivers constraints …
Thank you for your response. While a 4060 would generally be enough VRAM for the majority of ML tasks, LLMs have been requiring much more. For example, even the embedding algorithms I use for Retrieval-Augmented Generation require a ton of VRAM: MTEB Leaderboard - a Hugging Face Space by mteb. Meta’s Llama 3-70B runs too slow on a 4090 as well. My best guess is that these models will continue to get larger. Quantization can compress the size, but I want to have some room to be able to handle the next few iterations of open models.
Great point about the HDDs.
Edit re: cost - this is a fun hobby for me. I’m happy to spend the cash, albeit efficiently/wisely, to have a solid build.
Thanks again.
Thank you. I tried to work on a build at pcpartpicker, but I couldn’t find the motherboard I listed above. That might lack of searching skills. Is there a similar site for server builds? I might be wrong, but it seems like pcpartpicker is suited for workstations/towers.
It’ll definitely be a Linux build. It’ll also definitely be using 4 PNY NVIDIA A6000 GPUs as I already have those. Driving that will be Python (primarily PyTorch) and C++.
If that is the case just go for a Blackwell chip, the A6000 were released in 2020 and I hear equivalent Blackwell boards will be at the very least twice to three times as powerful.
