Server Build Help
Alrighty, For starters this is my first server build and I really don't know anything at all about servers. I really just need to know what components affect the quality of a server aside from network speeds, uplink, etc.
I'm gonna quickly throw (what my idea of) an ideal server build together.
- AMD FX-8350
- Mushkin Enhanced Silverline 16GB (2 x 8GB)
- GIGABYTE GA-990FXA
- Kingston 90GB SSD (BootDisk)
- (2X) Seagate Barracuda 2TB HDD (FileDisk)
- CORSAIR CX 600W Power Supply
- MSI Radeon HD 5450 1GB Video Card
Would something like this be alright for a "home server"? I'd probably only use it for hosting one or two game servers and a database for my website.
The reason I went with a 8 core processor is they are great for multitasking and data transfers. Obviously one wouldn't be great in gaming as most games don't use more than 2 cores, but from what I understand an 8 core should be great for a server.
Yeah so if anyone could give me some assistance that would be... greeaat.
Sure go for it, but if you might want to have just a tiny but better gpu for the game servers .
Okay, I always had the impression the reason servers had dedicated cards was just so you could navigate the OS and that's it. I'll have to look into that. Thanks!
fx 8320, a lot cheaper and exactly the same. only stock clockspeeds are the same. and why an 990fx board?
because 99% of the 970fx boards have crappy power delivery which can't handle neither the FX-8320 nor the FX-8350
This one can: http://pcpartpicker.com/part/asus-motherboard-m5a97r20
no it can't. 4+2 phases. that's a crappy one. get the m5a97 evo r2.0 6+2 phases or the 970a-ud3 from gigabyte. 8+2 phases. pretty good board.
No not the evo! that sucker only has 20 pci-e lanes! You have to get at least get the pro if you go ASUS
The M5A99FX Pro R2.0 is my optimal choice for the FX-8320 and FX-8350.
M5A99X EVO R2.0 is usually only 10-20 dollars cheaper than the Pro, and isn't really worth getting unless you're budget is super duper tight.
what are lanes for? there only is 1 little gpu in the build.
He does have a point.
fx 8320
hyper 212 evo/nzxt t40. 25$. it's worth it.
16gig ram. (low profile ram if you can due to cpu cooler, can be possible with normal height ram but if it don't, your fucktup.
m5a97 evo r2.0/gigabyte 970a-ud3. ( i think there still are crappy 990fx boards. get atleast a board with 6+2. 990fx boards are only if you wan't sli and more lanes. but your not going for 780ti sli so..
90gig? if there is a cheap 120-128gig ssd say 10$ more it is a good deal.
2x2tb
cheapest gpu you can find. wait for sales. saw some for 9.99$. get one with no fan. less noise and failure.
get a 80+ gold. normally i cheap out on the psu. i have a corsair cx500 and runs fine. cables are way to long in for my build but not that big of a deal. it's a server so it will run for really long times. get a really low wattage. if you have a 600watt psu and your build is 200watt max, 2hdd and an ssd and some fans, gpu will probably use 40watts or less. 125cpu 75gpu. that's 33% usage. and on 33% ussage it isn't gonna give you a good 80+ bronze rating. 450watt gold on pcpartpicker for 60$. end of the year you have it back.
note, don't try to play bf4 on a dualcore. runs really weird. 8 cores are used in bf4 max. consoles have there 8 core blablablabla you know. (6cores for gaming,1 for os, 1 not in use lol. that's what i have heard.)
there is no pro 970 from asus, we're talking about 970chipset here.
