Summary
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness,
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
GLX_SGI_video_sync
Extended renderer info (GLX_MESA_query_renderer):
Vendor: X.Org (0x1002)
Device: AMD Radeon ™ R9 Fury Series (FIJI, DRM 3.27.0, 5.0.0-17-generic, LLVM 8.0.0) (0x7300)
Version: 19.0.2
Accelerated: yes
Video memory: 4096MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 4.5
Max compat profile version: 4.5
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
Memory info (GL_ATI_meminfo):
VBO free memory - total: 3482 MB, largest block: 3482 MB
VBO free aux. memory - total: 4030 MB, largest block: 4030 MB
Texture free memory - total: 3482 MB, largest block: 3482 MB
Texture free aux. memory - total: 4030 MB, largest block: 4030 MB
Renderbuffer free memory - total: 3482 MB, largest block: 3482 MB
Renderbuffer free aux. memory - total: 4030 MB, largest block: 4030 MB
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 4096 MB
Total available memory: 8192 MB
Currently available dedicated video memory: 3482 MB
OpenGL vendor string: X.Org
OpenGL renderer string: AMD Radeon ™ R9 Fury Series (FIJI, DRM 3.27.0, 5.0.0-17-generic, LLVM 8.0.0)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 19.0.2
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_conservative_depth, GL_AMD_depth_clamp_separate,
GL_AMD_draw_buffers_blend, GL_AMD_framebuffer_multisample_advanced,
GL_AMD_gpu_shader_int64, GL_AMD_multi_draw_indirect,
GL_AMD_performance_monitor, GL_AMD_pinned_memory,
GL_AMD_query_buffer_object, GL_AMD_seamless_cubemap_per_texture,
GL_AMD_shader_stencil_export, GL_AMD_shader_trinary_minmax,
GL_AMD_texture_texture4, GL_AMD_vertex_shader_layer,
GL_AMD_vertex_shader_viewport_index, GL_ANGLE_texture_compression_dxt3,
GL_ANGLE_texture_compression_dxt5, GL_ARB_ES2_compatibility,
GL_ARB_ES3_1_compatibility, GL_ARB_ES3_2_compatibility,
GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,
GL_ARB_bindless_texture, GL_ARB_blend_func_extended,
GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
GL_ARB_clip_control, GL_ARB_color_buffer_float,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
GL_ARB_compute_variable_group_size, GL_ARB_conditional_render_inverted,
GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
GL_ARB_depth_clamp, GL_ARB_derivative_control, GL_ARB_direct_state_access,
GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
GL_ARB_occlusion_query2, GL_ARB_pipeline_statistics_query,
GL_ARB_pixel_buffer_object, GL_ARB_point_sprite,
GL_ARB_polygon_offset_clamp, GL_ARB_program_interface_query,
GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,
GL_ARB_shader_atomic_counter_ops, GL_ARB_shader_atomic_counters,
GL_ARB_shader_ballot, GL_ARB_shader_bit_encoding, GL_ARB_shader_clock,
GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote,
GL_ARB_shader_image_load_store, GL_ARB_shader_image_size,
GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_stencil_export, GL_ARB_shader_storage_buffer_object,
GL_ARB_shader_subroutine, GL_ARB_shader_texture_image_samples,
GL_ARB_shader_texture_lod, GL_ARB_shader_viewport_layer_array,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing,
GL_ARB_sparse_buffer, GL_ARB_stencil_texturing, GL_ARB_sync,
GL_ARB_tessellation_shader, GL_ARB_texture_barrier,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression_bptc,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map_array,
GL_ARB_texture_filter_anisotropic, GL_ARB_texture_float,
GL_ARB_texture_gather, GL_ARB_texture_mirror_clamp_to_edge,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_stencil8, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_uniform_buffer_object,
GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_viewport_array, GL_ATI_blend_equation_separate, GL_ATI_meminfo,
GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_EXT_abgr,
GL_EXT_blend_equation_separate, GL_EXT_depth_bounds_test,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB, GL_EXT_memory_object,
GL_EXT_memory_object_fd, GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
GL_EXT_provoking_vertex, GL_EXT_semaphore, GL_EXT_semaphore_fd,
GL_EXT_shader_integer_mix, GL_EXT_texture_array,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_integer, GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,
GL_EXT_vertex_attrib_64bit, GL_EXT_window_rectangles,
GL_IBM_multimode_draw_arrays, GL_KHR_blend_equation_advanced,
GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
GL_KHR_texture_compression_astc_ldr,
GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_pack_invert,
GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba,
GL_NVX_gpu_memory_info, GL_NV_conditional_render, GL_NV_depth_clamp,
GL_NV_packed_depth_stencil, GL_NV_texture_barrier, GL_NV_vdpau_interop,
GL_OES_EGL_image, GL_S3_s3tc
OpenGL version string: 4.5 (Compatibility Profile) Mesa 19.0.2
OpenGL shading language version string: 4.50
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
GL_AMD_multi_draw_indirect, GL_AMD_performance_monitor,
GL_AMD_pinned_memory, GL_AMD_query_buffer_object,
GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_stencil_export,
GL_AMD_shader_trinary_minmax, GL_AMD_texture_texture4,
GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
GL_APPLE_packed_pixels, GL_ARB_ES2_compatibility,
GL_ARB_ES3_1_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_bindless_texture,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
GL_ARB_color_buffer_float, GL_ARB_compatibility,
GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_ARB_direct_state_access, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_half_float_pixel,
GL_ARB_half_float_vertex, GL_ARB_indirect_parameters,
GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
GL_ARB_multi_draw_indirect, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
GL_ARB_query_buffer_object, GL_ARB_robust_buffer_access_behavior,
GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects,
GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops,
GL_ARB_shader_atomic_counters, GL_ARB_shader_ballot,
GL_ARB_shading_language_100, GL_ARB_shading_language_420pack,
GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_sparse_buffer,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression,
GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_multisample,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query,
GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,
GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_64bit,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_blend_equation_separate,
GL_ATI_draw_buffers, GL_ATI_fragment_shader, GL_ATI_meminfo,
GL_ATI_separate_stencil, GL_ATI_texture_compression_3dc,
GL_ATI_texture_env_combine3, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_copy_texture, GL_EXT_depth_bounds_test, GL_EXT_draw_buffers2,
GL_EXT_draw_instanced, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
GL_EXT_framebuffer_sRGB, GL_EXT_gpu_program_parameters,
GL_EXT_memory_object, GL_EXT_memory_object_fd, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_polygon_offset_clamp, GL_EXT_provoking_vertex,
GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_semaphore,
GL_EXT_semaphore_fd, GL_EXT_separate_specular_color,
GL_EXT_shader_integer_mix, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_array, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,
GL_EXT_transform_feedback, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control,
GL_KHR_debug, GL_KHR_no_error, GL_KHR_robust_buffer_access_behavior,
GL_KHR_robustness, GL_KHR_texture_compression_astc_ldr,
GL_MESA_window_pos, GL_NVX_gpu_memory_info, GL_NV_blend_square,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_NV_vdpau_interop,
GL_OES_EGL_image, GL_OES_read_format, GL_S3_s3tc,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 19.0.2
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
GL_AMD_framebuffer_multisample_advanced, GL_AMD_performance_monitor,
GL_ANDROID_extension_pack_es31a, GL_ANGLE_texture_compression_dxt3,
GL_ANGLE_texture_compression_dxt5, GL_APPLE_texture_max_level,
GL_EXT_base_instance, GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
GL_EXT_buffer_storage, GL_EXT_clip_cull_distance,
GL_EXT_color_buffer_float, GL_EXT_compressed_ETC1_RGB8_sub_texture,
GL_EXT_copy_image, GL_EXT_discard_framebuffer,
GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers,
GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex,
GL_EXT_frag_depth, GL_EXT_geometry_point_size, GL_EXT_geometry_shader,
GL_EXT_gpu_shader5, GL_EXT_map_buffer_range, GL_EXT_memory_object,
GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
GL_EXT_primitive_bounding_box, GL_EXT_read_format_bgra,
GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB_write_control,
GL_EXT_semaphore, GL_EXT_semaphore_fd, GL_EXT_separate_shader_objects,
GL_EXT_shader_implicit_conversions, GL_EXT_shader_integer_mix,
GL_EXT_shader_io_blocks, GL_EXT_tessellation_point_size,
GL_EXT_tessellation_shader, GL_EXT_texture_border_clamp,
GL_EXT_texture_buffer, GL_EXT_texture_compression_bptc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map_array,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_format_BGRA8888,
GL_EXT_texture_norm16, GL_EXT_texture_rg, GL_EXT_texture_sRGB_R8,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_type_2_10_10_10_REV,
GL_EXT_texture_view, GL_EXT_unpack_subimage, GL_EXT_window_rectangles,
GL_MESA_shader_integer_functions, GL_NV_draw_buffers,
GL_NV_fbo_color_attachments, GL_NV_image_formats, GL_NV_read_buffer,
GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil,
GL_OES_EGL_image, GL_OES_EGL_image_external,
GL_OES_EGL_image_external_essl3, GL_OES_EGL_sync,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
GL_OES_geometry_point_size, GL_OES_geometry_shader,
GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer,
GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box,
GL_OES_required_internalformat, GL_OES_rgb8_rgba8, GL_OES_sample_shading,
GL_OES_sample_variables, GL_OES_shader_image_atomic,
GL_OES_shader_io_blocks, GL_OES_shader_multisample_interpolation,
GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_surfaceless_context,
GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_buffer,
GL_OES_texture_cube_map_array, GL_OES_texture_float,
GL_OES_texture_float_linear, GL_OES_texture_half_float,
GL_OES_texture_half_float_linear, GL_OES_texture_npot,
GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
GL_OES_texture_view, GL_OES_vertex_array_object, GL_OES_vertex_half_float,
GL_OES_viewport_array
216 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x024 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x025 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x1a0 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1a1 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x1a2 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1a3 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x1a4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1a5 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x1a6 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1a7 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x1a8 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1a9 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x1aa 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1ab 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x1ac 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x1ad 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x1ae 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x1af 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x1b0 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x1b1 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x1b2 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x1b3 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x1b4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x1b5 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x1b6 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x1bd 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x1be 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x1bf 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x1c0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x1c1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x1c2 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x1c3 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x1c4 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x1c5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x1c6 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x1c7 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x1c8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x1c9 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x1ca 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x1cb 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x1cc 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x1cd 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x1ce 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x1cf 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x1d0 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1d1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x1d2 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1d3 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x1d4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x1db 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x1dc 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x1dd 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x1de 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x1df 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x1e0 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x1e1 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x1e2 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x1e3 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x1e4 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x1e5 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x1e6 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x1e7 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x1e8 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x1e9 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x1ea 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x1eb 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x1ec 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x1ed 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x1ee 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x1ef 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x1f0 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x1f1 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x1f2 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x1f9 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x1fa 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x1fb 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x1fc 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x1fd 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x1fe 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x1ff 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x200 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x201 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x202 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x203 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x204 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x205 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x206 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x207 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x208 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x209 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x20a 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x20b 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x20c 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x20d 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x20e 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x20f 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x210 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x217 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x218 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x219 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x21a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x21b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x21c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x21d 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x21e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x21f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x220 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x221 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x222 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x223 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x224 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x225 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x226 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x227 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x228 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x229 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x22a 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x22b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x22c 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x22d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x234 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x235 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x236 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x237 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x238 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x239 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x23a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x23b 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x23c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x23d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x23e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x23f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x240 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x241 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x242 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x243 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x244 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x245 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x246 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x247 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x248 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x249 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x24a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x24b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x252 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x253 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x254 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x255 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x256 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x257 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x258 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x259 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x25a 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x25b 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x25c 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x25d 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x25e 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x25f 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x260 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x261 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x262 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x263 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x264 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x265 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x266 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x267 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x268 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x269 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x270 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x271 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x272 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x273 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x274 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x275 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x276 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x277 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x278 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x279 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x27a 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x27b 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x27c 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x27d 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x27e 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x27f 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x280 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x281 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x282 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x283 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x284 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x285 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x286 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x287 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x055 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x28e 32 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x28f 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x290 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x291 32 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x292 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x293 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x294 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x295 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x296 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x297 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x298 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x29c 32 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x29d 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x29e 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x29f 32 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x2a0 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x2a1 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x2a2 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x2a3 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x2a4 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x2a5 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x2a6 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x2a7 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
264 GLXFBConfigs:
0x056 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x057 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x058 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x059 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x05a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x05b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x05c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x05d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x05e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x05f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x060 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x061 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x062 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x063 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x064 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x065 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x066 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x067 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x068 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x069 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x06a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x06b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x06c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x06d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x074 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x075 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x076 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x077 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x078 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x079 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x07a 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x07b 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x07c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x07d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x07e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x07f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x080 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x081 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x082 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x083 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x084 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x085 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x086 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x087 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x088 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x089 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x08a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x08b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x092 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x093 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x094 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x095 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x096 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x097 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x098 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x099 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x09a 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x09b 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x09c 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x09d 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x09e 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x09f 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x0a0 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x0a1 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x0a2 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x0a3 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x0a4 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x0a5 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x0a6 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x0a7 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x0a8 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x0a9 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x0b0 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x0b1 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x0b2 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x0b3 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x0b4 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x0b5 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x0b6 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x0b7 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x0b8 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x0b9 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x0ba 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x0bb 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x0bc 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x0bd 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x0be 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x0bf 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x0c0 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x0c1 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x0c2 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x0c3 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x0c4 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x0c5 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x0c6 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x0c7 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x0ce 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x0cf 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0d0 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x0d1 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0d2 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x0d3 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x0d4 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x0d5 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0d6 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x0d7 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0d8 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x0d9 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0da 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x0db 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0dc 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x0dd 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0de 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x0df 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x0e0 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x0e1 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0e2 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x0e3 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0e4 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x0e5 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0ec 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0ed 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x0ee 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0ef 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x0f0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0f1 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
0x0f2 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x0f3 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x0f4 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x0f5 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x0f6 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x0f7 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow
0x0f8 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0f9 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x0fa 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0fb 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x0fc 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0fd 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow
0x0fe 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0ff 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x100 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x101 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x102 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x103 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x10a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x10b 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x10c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x10d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x10e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x10f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x110 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x111 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x112 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x113 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x114 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None
0x115 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x116 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x117 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x118 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x119 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x11a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None
0x11b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x11c 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x11d 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x11e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x11f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x120 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x121 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x128 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x129 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x12a 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x12b 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x12c 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x12d 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 16 16 16 16 0 0 Slow
0x12e 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x12f 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x130 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x131 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x132 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x133 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 16 16 16 16 0 0 Slow
0x134 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x135 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x136 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x137 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x138 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x139 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 16 16 16 16 0 0 Slow
0x13a 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x13b 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x13c 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x13d 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x13e 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x13f 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 16 16 16 16 0 0 Slow
0x146 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x147 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x148 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x149 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x14a 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 None
0x14b 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 16 16 16 0 0 0 Slow
0x14c 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x14d 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x14e 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x14f 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x150 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 None
0x151 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 16 16 16 0 0 0 Slow
0x152 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x153 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x154 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x155 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x156 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 None
0x157 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 16 16 16 0 0 0 Slow
0x158 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x159 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x15a 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x15b 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x15c 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 None
0x15d 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 16 16 16 0 0 0 Slow
0x164 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x165 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x166 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x167 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x168 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x169 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow
0x16a 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x16b 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x16c 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x16d 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x16e 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x16f 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x170 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x171 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x172 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x173 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x174 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None
0x175 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow
0x176 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x177 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x178 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x179 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x17a 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None
0x17b 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x182 32 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x183 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x184 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x185 32 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x186 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x187 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x188 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x189 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x18a 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x18b 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x18c 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x18d 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x191 32 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x192 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x193 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 None
0x194 32 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x195 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x196 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 None
0x197 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x198 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x199 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 None
0x19a 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x19b 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
0x19c 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 None
