Does the Looking Glass spice interface support send-key from the host into the vm?
I’m trying to automate hitting scroll-lock to capture the mouse by using ‘virsh send-key (vm-name) 71’ but not having much luck.
The Scroll Lock
keybind is not a SPICE keybind, it’s part of the LG client. so no.
As @gnif mentioned the Scroll-Lock function is captured by the LG Client application. As this is a X11 application, you can send it keyboard events like any other application. To demonstrate, install “xdotool” on your Linux system then run:
xdotool search --name 'Looking Glass \(client\)' key Scroll_Lock
This should toggle the scroll-lock function in the LG client.
This works well. Thanks.
