Select NAS hardware (recommendations and help)
Hi, this is my first post so sorry if I missed a related thread, rules or tags.
After watching “Mini Server!!!” I am about ready to finally get my own home NAS. I originally thought about getting a prebuilt(bundle like synology) unit but found that I was more interested in building my own.
I am lucky enough to have a micro center near me and was looking at the sever Wendell showed off. I found a different version on sale. My basic question is is there any reason I should not get the cheaper more workstation version?
Original
Workstation
As far as I can tell the difference are
  • 2.5 Gb
  • A few more cores
  • integrated graphics
  • more PCIE
The cpu is still 80W. Is there anything i am giving up?
To be clear I am not just using it as storage and share. I wanted to run a VM some docker instances and a few other projects. It does not need to be supper powerful but not weak either.
Depends on what you actually want to do, to just serve files both are quite overpowered. Both are using rather old hardware by now however fwiw.
I was planning on running some containers, VMs and a few other home projects off it.
Is there anything newer you recommend around the same prices?
I’m not sure what the thread is about. Pre-built or DIY?
Being cheap you might want to have look at a Dell PRECISION 3650 TOWER and rip out all extras, below 700 USD with a 11th gen Xeon CPU, 8Gb of ECC and vPro (not sure if always includes KVM functionality etc).
If it is just serving files the Argon EON RPi NAS plus a RPi 4 should cost you $300, houses 4 SATA SSDs, draws roughly 20W total and could be just what you need, here.
Of course if you need MOAR POWAH I do think you should look somewhere else.
It’s also a not so great SoC for the job, no crypto (SMB) and according to Toms Hardware everything hangs off USB :-/
Prebuilt I linked to the microcenter web site. I could do a DIY but it seems easer to get a pre built.
I was more referring to a synology vs my own install and configuration.
Thanks ill look into that, ill look into the dell and good to know about SMB and USB
With the argon case they are proving a NVME SATA drives at 600 MB/second not great in a PC, but for a Pi4 it’s not a bad choice. But in no way should be considered a NAS for anything but Pi’s and maybe your phone.
I’ll take the RK3399 SoC any day of the week over the Broadcom one :slight_smile: if you’re looking at cheap ARM SoCs. Sadly projects like https://kobol.io/ folded due to the pandemic :frowning:
