I’ve been running the latest version of proton 4.2-2. When I run it with Proton 3.16-8 Beta I don’t even get a black window launching for a few seconds. In the terminal it seems to have the same error.
~$ steam steam://run/814380
Running Steam on ubuntu 18.04 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Installing breakpad exception handler for appid(steam)/version(1550534751)
Gtk-Message: 12:19:33.748: Failed to load module “gail”
Gtk-Message: 12:19:33.748: Failed to load module “atk-bridge”
(steam:12828): Gtk-WARNING **: 12:19:33.753: Unable to locate theme engine in module_path: “adwaita”,
/usr/share/themes/Arc-Dark/gtk-2.0/main.rc:1090: error: unexpected identifier ‘direction’, expected character ‘}’
/usr/share/themes/Arc-Dark/gtk-2.0/apps.rc:91: error: unexpected identifier ‘direction’, expected character ‘}’
[0417/121934.139962:INFO:crash_reporting.cc(242)] Crash reporting enabled for process: browser
[0417/121934.170160:WARNING:crash_reporting.cc(281)] Failed to set crash key: UserID with value: 0
[0417/121934.170236:WARNING:crash_reporting.cc(281)] Failed to set crash key: BuildID with value: 1550527787
[0417/121934.170243:WARNING:crash_reporting.cc(281)] Failed to set crash key: SteamUniverse with value: Public
[0417/121934.170249:WARNING:crash_reporting.cc(281)] Failed to set crash key: Vendor with value: Valve
[0417/121934.175331:ERROR:gpu_process_transport_factory.cc(1026)] Lost UI shared context.
CApplicationManagerPopulateThread took 2 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
** (steam:12828): WARNING **: 12:19:34.341: Unknown device type 14
** (steam:12828): WARNING **: 12:19:34.341: Could not create object for /org/freedesktop/NetworkManager/Devices/1: unknown object type
CAppInfoCacheReadFromDiskThread took 58 milliseconds to initialize
Opted-in Controller Mask for AppId 0: 0
** (steam:12828): WARNING **: 12:19:34.462: Ignoring invalid property ‘autoconnect-priority’
** (steam:12828): WARNING **: 12:19:34.462: Unknown setting ‘proxy’
** (steam:12828): WARNING **: 12:19:34.462: Ignoring invalid property ‘route-data’
** (steam:12828): WARNING **: 12:19:34.462: Ignoring invalid property ‘address-data’
Local Device Found
type: 0e6f 0213
path: sdl://0
serial_number: - 0
Manufacturer:
Product: Afterglow
Release: 100
Interface: -1
!! Steam controller device opened for index 0.
Steam Controller reserving XInput slot 0
(steam:12828): Gtk-WARNING **: 12:19:34.826: gtk_disable_setlocale() must be called before gtk_init()
Controller 0 connected, configuring it now…
Controller has an Invalid or missing unit serial number, setting to ‘e6f-213-c3cfd6d’
Controller device closed after hid_read failure
!! Controller 0 attributes:
Type: 31
ProductID: 531
Serial: e6f-213-c3cfd6d
Capabilities: 001843ff
Firmware Version: 0
Firmware Build Time: 2147483647 (Tue, 19 Jan 2038 03:14:07 GMT)
Bootloader Build Time: 2147483647 (Tue, 19 Jan 2038 03:14:07 GMT)
Could not load local selection (), local override (/home/caleb/.local/share/Steam//controller_config/bigpicture.vdf), or user path (/home/caleb/.local/share/Steam/userdata/205323629/config/controller_configs/bigpicture.vdf), checking last resort path: /home/caleb/.local/share/Steam//controller_base/bigpicture.vdf
Loaded Config for Last Resort Path for App ID 413090: /home/caleb/.local/share/Steam//controller_base/bigpicture.vdf
[413090]Non-Steam Controller Configs Enabled: 1
Loaded Config for Local Override Path for App ID 413080: /home/caleb/.local/share/Steam//controller_base/empty.vdf
[413080]Non-Steam Controller Configs Enabled: 1
Controller 0 disconnected
Fatal : VkResult is “ERROR_INITIALIZATION_FAILED” in /home/pgriffais/src/Vulkan/base/vulkanexamplebase.cpp at line 823
vulkandriverquery: /home/pgriffais/src/Vulkan/base/vulkanexamplebase.cpp:823: void VulkanExampleBase::initVulkan(): Assertion `res == VK_SUCCESS’ failed.
Aborted (core dumped)
Local Device Found
type: 0e6f 0213
path: sdl://0
serial_number: - 0
Manufacturer:
Product: Afterglow
Release: 100
Interface: -1
roaming config store loaded successfully - 4952 bytes.
migrating temporary roaming config store
[0417/121935.976016:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
[0417/121936.005179:WARNING:crash_reporting.cc(281)] Failed to set crash key: UserID with value: 0
[0417/121936.005275:WARNING:crash_reporting.cc(281)] Failed to set crash key: BuildID with value: 1550527787
[0417/121936.005282:WARNING:crash_reporting.cc(281)] Failed to set crash key: SteamUniverse with value: Public
[0417/121936.005289:WARNING:crash_reporting.cc(281)] Failed to set crash key: Vendor with value: Valve
[0417/121936.005950:INFO:crash_reporting.cc(242)] Crash reporting enabled for process: gpu-process
Failed to init SteamVR because it isn’t installed
BYieldingQueryAccountsRegisteredToController
ExecCommandLine: “’/home/caleb/.local/share/Steam/ubuntu12_32/steam’ ‘steam://run/814380’”
ExecuteSteamURL: “steam://run/814380”
System startup time: 2.99 seconds
Opted-in Controller Mask for AppId 413080: 0
Type: 31
ProductID: 531
Firmware Version: 0
Loaded Config for Local Selection Path for App ID 413090: /home/caleb/.local/share/Steam/steamapps/workshop/content/241100/1689651975/1007024772344596662_legacy.bin
Loaded Config for Local Selection Path for App ID 413090: /home/caleb/.local/share/Steam/steamapps/workshop/content/241100/1557882944/956347096063782645_legacy.bin
[0417/121936.522160:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
Opted-in Controller Mask for AppId 814380: d
Loaded Config for Local Selection Path for App ID 814380: /home/caleb/.local/share/Steam/steamapps/workshop/content/241100/1668826331/994637970746554033_legacy.bin
[814380]Non-Steam Controller Configs Enabled: 1
Loaded Config for Local Override Path for App ID 814380: /home/caleb/.local/share/Steam//controller_base/empty.vdf
GameAction [AppID 814380, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with “”
sh: 1: /home/caleb/.local/share/Steam/legacycompat/iscriptevaluator.exe: Exec format error
sh: 1: /home/caleb/.local/share/Steam/steamapps/common/Sekiro: Permission denied
sh: 1: /home/caleb/.local/share/Steam/steamapps/common/Steamworks Shared: Permission denied
[2019-04-17 12:19:33] Startup - updater built Feb 18 2019 22:08:53
[2019-04-17 12:19:33] Verifying installation…
[2019-04-17 12:19:33] Verification complete
installscript_posix.cpp (357) : Assertion Failed: strCommonRedistForeignInstallPath != “”
assert_20190417121936_25.dmp[13035]: Uploading dump (out-of-process)
/tmp/dumps/assert_20190417121936_25.dmp
JS method call WebChat.GetWebChatLanguage with 1 arguments
installscript_posix.cpp (418) : Assertion Failed: Standalone evaluator returned error code for app 814380
GameAction [AppID 814380, ActionID 1] : LaunchApp changed task to SynchronizingCloud with “”
JS method call WebChat.RegisterForFriendPostMessage with 1 arguments
JS method call WebChat.RegisterOverlayChatBrowserInfoChanged with 1 arguments
JS method call WebChat.GetSignIntoFriendsOnStart with 1 arguments
JS method call WebChat.GetCurrentUserAccountID with 1 arguments
JS method call WebChat.GetWebChatURL with 1 arguments
GameAction [AppID 814380, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with “”
GameAction [AppID 814380, ActionID 1] : LaunchApp changed task to CreatingProcess with “”
GameAction [AppID 814380, ActionID 1] : LaunchApp waiting for user response to CreatingProcess “”
GameAction [AppID 814380, ActionID 1] : LaunchApp continues with user response “CreatingProcess”
Game update: AppID 814380 “”, ProcID 13039, IP 0.0.0.0:0
Adding process 13039 for game ID 814380
GameAction [AppID 814380, ActionID 1] : LaunchApp changed task to WaitingGameWindow with “”
GameAction [AppID 814380, ActionID 1] : LaunchApp changed task to Completed with “”
ERROR: ld.so: object ‘/home/caleb/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so’ from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
/bin/sh: 1: /home/caleb/.local/share/Steam/steamapps/common/Sekiro/sekiro.exe: Exec format error
Adding process 13044 for game ID 814380
JS method call FriendSettings.RegisterForSettingsChanges with 1 arguments
JS method call WebChat.RegisterForPushToTalkStateChange with 1 arguments
JS method call WebChat.SetVoiceChatActive with 1 arguments
JS method call WebChat.RegisterForComputerActiveStateChange with 1 arguments
JS method call SharedConnection.AllocateSharedConnection with 1 arguments
JS method call FriendSettings.GetEnabledFeatures with 1 arguments
assert_20190417121936_25.dmp[13035]: Finished uploading minidump (out-of-process): success = yes
assert_20190417121936_25.dmp[13035]: response: CrashID=bp-d75c417e-e8de-45a1-97dd-829152190417
assert_20190417121936_25.dmp[13035]: file ‘’/tmp/dumps/assert_20190417121936_25.dmp’’, upload yes: ‘‘CrashID=bp-d75c417e-e8de-45a1-97dd-829152190417’’
JS method call SharedConnection.SubscribeToEMsg with 2 arguments
JS method call SharedConnection.SubscribeToClientServiceMethod with 2 arguments
JS method call SharedConnection.RegisterOnLogonInfoChanged with 2 arguments
Game removed: AppID 814380 “”, ProcID 13039
JS method call SharedConnection.SendMsgAndAwaitResponse with 3 arguments
JS method call Storage.GetString with 2 arguments
JS method call WebChat.GetOverlayChatBrowserInfo with 1 arguments
JS method call Parental.RegisterForParentalSettingsChanges with 1 arguments
JS method call Broadcast.RegisterForBroadcastStatus with 1 arguments
JS method call Broadcast.RegisterForViewerRequests with 1 arguments
JS method call SharedConnection.RegisterOnMessageReceived with 2 arguments
JS method call SharedConnection.SendMsg with 2 arguments
JS method call WebChat.GetPushToTalkEnabled with 1 arguments
JS method call WebChat.SetNumChatsWithUnreadPriorityMessages with 1 arguments
JS method call WebChat.BSuppressPopupsInRestore with 1 arguments
