Seemingly random bluescreens
ok so after installing a new mobo (gigabyte 99fxa ud5 ver4.0) i get blue screens at random
im getting
IRQL_NOT_LESS_OR_EQUAL
DRIVER_OVERRAN_STACK_BUFFER
PAGE_FAULT_IN_NONPAGED_AREA
and now
ATTEMPTED_WRITE_TO_READONLY_MEMORY
a few moments ago
KMODE_EXCEPTION_NOT_HANDLED
system is as follows
32gb ram
256gb kingston ssd
1000 watt PSU
Dual Gtx 680 superclock editions
amd fx 8 core. 8150
i have run full tests with every stick of ram individualy with memtest86 and all of the hardware runs perfectly on my old board
system is liquid cooled so none of my teps get much higher then 35-40 c at load
help?
please?
Random blue screens can be caused most often by faulty hardwer, like power supply...
  • Did you reinstall OS after installing a new mobo? If you didn't maybe there is some conflict between drivers.
  • Overclocking? Try increasing CPU voltage a bit. If that doesn't work try decreasing OC freq.
  • You could try downloading Whocrashed and read the crash log for more info (crash dump analysis).
yeah i re installed multiple times. turned out it was a bad northbridge on the new mobo i had bought.
