I can't take ownership of my Shell32.dll and my explorerframe.dll and I need these two to install my theme so i can change my ORB and explorer, any help would be nice and also I can't use Maks hackx video becasuse mine needs these two files to install my theme if any of you are asking I am using Dynamic_Black_____by_DjabyTown and the ORb changer that is in the maks hack video won't help me at all.
You may have to register it, I'm not sure if it will help but I've ran into similar problems before and this helped me. First both files should be in the windows directory in the system32 folder. Next get into an elevated command prompt and type this:
regsvr32 %windir%\syswow64\shell32.dll
regsvr32 %windir%\syswow64\explorerframe.dll
Obiously replace syswow64 for syswow32 if you're using a 32 bit windows. Hope this helps! If it doesn't we'll figure something out!
So just run CMD as admin, and paste these in or what? lol I am kinda a noob to CMD 9as sad as that sounds)
And I am running windows 7 ultimatex64
Yeah, just make sure you're running cmd as admin and type those commands in, I'm not sure if it will work or not but it's worth a shot
The Shell32.ddl worked but
Didn't work so I am at a lose here.
Well it might help if I read the thread right the first time. This should work. Do this is an elevated command prompt:
takeown /f explorerframe.dll
I got it all working now thanks! :) only thing that wount change is my ORB but I will change that later.
i used this
http://universal-theme-patcher.en.softonic.com/
then this
http://windows-7-start-button-changer.en.softonic.com/
also this
http://windows-7-boot-updater.en.softonic.com/
for my customisation needs this is also a good theme that self installs after you use the theme patcher xenomorph by babosa
http://windows7themes.net/30-best-dark-custom-windows-7-themes.html
hope that helps
