Seyunx
1
Hey guys! A friend of mines needs help building a computer, what are your recommendations for a PC that costs 500-600$ (No Harddrive /windows needed)
Ive seen some deals online I'm sure buying parts and assembling one yourself is much cheaper/price effective.
Thanks for the all the help I can get :)
What is this computer going to be used for braoh
Seyunx
3
Going to game with it :P ofc! What else? xD Budget PC!
Seyunx
4
Did everyone already go to sleep? :(
Warpig
5
MSI 97a-g46 motherboard
AMD phenom 2 x4 965 cpu
caviar blue hdd 500 gb
kingston hyperx 3k ssd
gigabyte gtx 650 GPU
coolermaster hyper 212+ cpu cooler
NZXT source 210 case
cooler master GX 480 watt 80+ bronze power supply
Slimm
6
http://pcpartpicker.com/p/Fkpx maybe?
Seyunx
7
That looks really good! I though the Phenom 4X bottlenecks the 7870 though..
Slimm
8
I don't think so, it'll be fine i'm sure
Seyunx
9
Hmm would love if someone else proved a Phenom II X4 dosnt bottle neck a AMD 7870
Slimm
10
a lil google magic http://www.tomshardware.com/forum/365847-28-will-phenom-bottleneck-7870
there are a lot of people asking that question, so go look at other forums such as this one
http://pcpartpicker.com/p/Fo2H
This is what I would do. FX-6300 and 7870 GHz should go very well together, But the old 965 is a good pick too
Seyunx
12
Gusy wouldI need thermal paste with that last build? It looks awesome :D
Ehone
13
no you get it with the 212 evo.
http://pcpartpicker.com/p/Fu7c
Try that,the GPU is nearly on par with a 7950.
