I just got my grubby little hands on a Seeed reServer, they’re having great deals on the i3 variant 4c/8t. I do wish the i5 was in stock, would have loved to have the TB4 expandability, but oh well.
As I was watching Wendell’s update on the Mach2 dual-actuator HDDs being available for SATA, I figured that would give me the option to do a 4-disk RAID using to physical disks. This then got me to ask myself if a similar option was available using multiple physical disks instead but with a bigger count of disks (and maybe less power) using M.2 AHCI disks.
Enter, SATA port replication (PR). Reddit gave the impression that SATA PR is unreliable, and we should just stick with SAS PR. Except, SAS HBA’s are humungous, and I don’t need any RAID functionality, just a JBOD-style connection.
Ultimately, I’ve come to a couple of conclusions:
- Use a SATA PR approach with something like this:
https://www.aliexpress.com/item/1005005446052789.html
Assuming SATA PR is super-usable and stable, this would give me a lot of capacity and redundancy while consuming less power and not requiring any cabling hijinks.
- Go for a SATA JBOD approach using something like this:
This is in theory small enough to fit into the case’s dimensions but the positioning kind of worries me. I could get some SATA to to M.2 adapters like this one, which fits my needs almost perfectly:
https://www.silverstonetek.com/en/product/info/storage/SDP11/
The cabling will be bonkers lol. If the power connector lines up (which I don’t think it does), I’ll need L cables for SATA. Or I’ll have to rotate the caddy 180 degrees and extend the SATA power cable, which is ok-ish, but the SATA data cables needed are short, and most SlimSAS to SATA cables are longer than I’ll need for this use case. Looming probably needed.
I get a SAS HBA and take a similar route to 2, but I’ll probably need a 3D printed top and a PCIe ribbon cable. I would LOVE to have a SAS HBA also providing eSAS so I could in the future connect up an LTO drive. I could also use 2. for the internal disks and use the approach from 3. to connect an FC HBA instead, since LTO drives support point-to-point FC connections.
Say “To hell with it” and just get Mach2 HDD’s and pretend URE’s aren’t a thing. Since this isn’t mission critical data (home-labbing), I don’t mind too much, but I’d love to have options for more reliability and expandability. 2HDDs with 4 VDEVs is kinda restricting is all.
I don’t want to go the USB route since I love the reServer form factor. Let me know what you guys think?
