Secondary HDD Disappearing
Hey guys. I have come across an issue that I can't seem to solve. I have an ssd and an hdd. My hdd is my secondary storage. Every now and then it disappears while in Windows 7. It'll even disappear while writing to it. It doesn't happen often, but enough to be annoying. I have configured it to stay always on and recconected the sata ports, but it hasn't helped. Any ideas?
Is it on a mount point or did you assign a drive letter to it?  I set up a second drive on my brothers pc as a mount point and sometimes it won't show up on the windows share so I type the location in the address bar to access it.
Hello,
            Was going to post about this same issue..i have returned the hdd thinking it was defective but that wasn't  the case..idk , the problem may be with windows. I may try connecting to another sata port (i would have done this already but was afraid it would wipe my drive) I have had simular issues in the past on older builds too where my secondary loses its data or dissapears completely from windows.
 my system specs Operating System / Microsoft Windows 7 Home Premium Edition 64-bit Processors / Intel Core i7 920 @ 2.67ghz Motherboard / Intel X58 / MSI MS-7591 System memory / 12gb DDR3-SDRAM (1333 MHz) Hard Drives / Seagate 7200rpm , 500gb / Western Digital Raptor , 150 gb Optical Drives / Dvd+-RW Video / Nvida Geforce Evga GTX 570 1.25 gb / Gpu Clock 732 mhz , Memory Clock 1900 mhz Displays / 20inch Hp Main Monitor / 37inch Dell W3706MC Secondary Monitor
moving the drive to another SATA port will not wipe the drive
I will try another sata port. It has been assigned a letter
