Secondary Build (light use/gaming)
I bought a MB from someone I work with a few weeks ago, and I've decided to build a second computer (cheapish).  I'm buying parts slowly, a few per paycheck and I wanted to check to make sure everything is all good!
MB- MSI p43 Neo-F
CPU- e8400 (would be heavily overclocked)
RAM- 4gb of generic ddr2 (I think I won a bid on ebay for a kit, if not I'll be buying some soon, not too concerned about this)
GPU- MSI 7770ghz edition
PSU- OCZ Modstream 520w (only because I'm a big fan of ocz psu's and I like the modular feature)
Case- NZXT Source 210 (thrilled to build in this case, seems awesome for the price)
Currently I have the MB, GPU, and a CPU cooler (212 evo), the ram, case, and either psu or CPU are coming in the next week or 2 (I get paid friday).  I'll be using a spare HDD I have laying around so thats not a problem either.
So my questions are:
Is the CPU/GPU combo going to be good enough for gaming on low settings ("modern" games, ie. Rise of the triad, sleeping dogs, arma 2, bioshock infinite, etc.)?  Or will the cpu bottleneck, etc.?  Is there a better CPU for this build within my budget? (under $50)?
OCZ is out of business, sorry mate.  go for a different brand so you can receive a warranty and support. maybe a seasonic, corsair, or antec PSU.
hmm, a old dual core with no hyperthreading?  you will probably have some issues there.  try to find a core2quad on ebay maybe
i found lots of Q6600 CPUs on ebay for about 50 bucks.  should be able to overclock those pretty well.
Completely forgot about ocz, whoops.  I'll be changing that.  I'll look at a q6600, any other suggestions?
mmm, just keep an eye on your CPU temp when overclocking.  X58 is a hot platform.  on my old FTW3 motherboard my northbridge was always idling around 82c which i wasnt worried about, but just a warning.  Use RealTemp to view CPU temps when overclocking, but that 212 should suffice.
Are you sure its x58?  I thought the NB was p43 on that MB.
doh, my bad.
