Second Version of my First Build
You all helped me out a tonne before so I thought I would ask for your help again. Since last time I posted here I've come to realise AMD CPUs and GPUs have a lot of potential. So this is my new build - http://uk.pcpartpicker.com/p/Bqdb.
Is there anywhere that you think improvements may be made. Also, I'm probably going to wait for a few months until I have the money to purchase this its just that I want to get the basic structure there, so the price will probably come down which is good.
The purposes for this build are gaming, recording and editing. I'm not really bothered about wait times when editing though. So I don't mind not going for CUDA.
Thanks for any help you can give.
All I can suggest is try to grab a Ghz edition card, but looks pretty good. Could save a bit by going with 1600mhz memory. I know a lot of people suggest 1866, but it's not going to help much with the current generation of graphics cards having like 2GB of ram. Also look into an extreme3 board, rather than the 4. THe only real difference between the two is that the extreme4 supports sli and crossfire. If you only play to use one card, go with the extreme3. Good luck.
