Hi there.
For some time now, I’m been the happy owner of the Samsung CRG9, but awesome thought it may be, the stand is way to big, or deep rather. If I really make an effort, from the wall to the very back of the monitor, I can perhaps get 16.5 cm (some 6 1/2 inches). That needs to be less, and preferably whatever solution I end up with, should be mounted permanently to my desk.
The standard stand is quite good actually, including 3 adjustable axis and of course height adjustment too, however all I really need is height and tilt adjustment, and I’d be quite okay with these adjustments having to be set permanently. Once I’ve set it up to my preferences, I’ve got not need to adjust.
The issue of course is that I’ve been searching far and wide for a solution, and I haven’t even succeeded in finding a bad one. I mean I basically just need a stick with a vesa mount on the end of it.
So, I hope that someone can help.
Also while I do prefer cheap rather than expensive, money isn’t really an issue. This is a matter of achieving perfection, and you can’t put a price on that.
Best regards.
edit:
I think I’ve actually found the perfect solution… sort of.
It not quite high enough, but I can work around that, height adjustment is difficult and there’s no tilt, but who needs that anyway. Also it’s very easy to mod.
Anyway, here’s the link and unless anyone come up with some brilliant idea, that’s what I’m ordering.
