Seagate Momentus xt (2 gen) 750GB
Has anyone had a chance to play with or use the more recent seagate momentus xt 750GB,
I was just wondering as I need a lot of storage in a my audio work laptop and I do need speed as it helps when recording and general proccessing. Plus I dual boot.  Hence why an ssd maybe unsuitable due to the cost for a higher capacity.
Other wise do you otherwise have any other recomendations for a fast drive, with 750GB is a minimum must be an internal drive. And not be painfully expensive.
Cheers
Ciaran
since its a laptop you dont have very many options i think thats your best bet right there
