Seabios and GPU passthrough - what am I missing?
Situation: I am currently running Proxmox and have several VMs installed which use GPU passthrough, which work wonderfull with OMVF (OSX Big Sur, Windows 10, Linux Manjaro).
Problem: But I can’t for the life of me get GPU passthrough working with SeaBIOS. I just get a blank screen and the VM hangs at around 25% or 50% CPU usage of its assigned cores, but the GPU fans slow down. It doesn’t even show the SeaBIOS Splashscreen/Boot. I intend to use SeaBIOS for booting Windows XP and Windows 7, so I can get rid of my legacy PCs. Strangly, I never got SeaBIOS running with GPU passthrough on any other host-systems in the past (Ubuntu, Arch, on various different boards with intel i5 4xxx and Xeon CPUs, several GPU from the GTX 660 line) only OVMF works - most people struggle with OVMF but get SeaBIOS running without issues. I couldn’t find specifics on my issue, So maybe I am missing something elementary.
My System:
Mainboard: MSI Z390-A Pro
CPU: Intel i7 8700K
RAM: 16GB RAM DDR4
GPU1: Geforce GTX 970 (16x PCIe Slot) - Passthrough with OMVF works
GPU2: Geforce GTX 760 (4x PCIe Slot) - Passthrough with OMVF works
GPU3: Intel iGPU for boot and terminal output but its not connected to anything
Passthrough configuration in Proxmox:
  • I simply blacklisted nvidia, nouveau and radeon drivers. None of the PCIe GPUs is used or initialised at boot.
  • I don’t use vfio-pci at all
Things I tried:
  • I tried passthrough with both GPUs of course. No Output.
  • I dumped the BIOS from the GTX 760 and loaded it with romfile option in the VM. No Output.
  • I tried booting with the “default” screen device from Proxmox (which is a virtual adapter which pushes the output to noVNC), so I can at least start WinXP and boot into the desktop. I get an error 12 (not enough resources for this device) in the device manager for the nvidia GPU
The VM config in Proxmox:
boot: order=ide0
cores: 2
hostpci0: 03:00.1
hostpci1: 03:00.0,x-vga=1
ide0: cold-vm:vm-100-disk-0,size=100G
ide2: cold-iso:iso/Windows_XP_Pro_OEM_Z77_SATA.iso,media=cdrom
machine: pc-i440fx-5.2
memory: 4096
net0: rtl8139=FE:B0:56:AE:40:3F,bridge=vmbr1,firewall=1
numa: 0
ostype: wxp
smbios1: uuid=e15bed7d-279f-44e8-90f9-d11feaf73a03
sockets: 1
vga: none
vmgenid: 80928d85-df74-43a2-b9e7-4e17573ae4eb
