I have atm an old HP 2009m 20 inch monitor at 60hz widescreen and my in game fps is about 150-200 though the screen tear is VERY noticible and I'm well aware of V-Sync only because of my 60Hz refresh rate it caps my fps at 60Fps... Is there anyway to change this or Fix it mayberun a certain software? Or will I have to go and Buy my self a new monitor with a beter polling time and refresh rate...
try updating the graphics card drivers
If you are using an nvidia card, try to activate Adaptive Vsync in the nvidia control panel.
Adaptive vsync will turn on vsync if the framerate goes above your refresh rate, and turn vsync off when drops below your refresh rate.
But if you really want to keep your 150-200 fps rate get a 120 or 144hz monitor.
