before i get started my specs are.
windows 7 pro (up to date)
Intel 4770k
Gtx 780
LG 23EA63 (monitor) -using dvi *1080p
AOC e2752v (secondary monitor) - using hdmi *1080p
My issue started when i uninstalled a program called "Air Display" which enabled me to use my ipad as another monitor. When i finished the uninstall my computer had to do a restart to finalize it and after i put in my password and windows loaded the entire screen enlarged making it look as if it where at a lower resolution but everywhere i look it tells me i am at 1080p. I made sure all my drivers are up to date and restarted my computer a couple of times but the problem remains.
Does anyone know of a setting somewhere to downscale windows default screen density or something like that.
Thanks for the help!
