Screeching monitor noise
Just got my new PC set up. Have a 23 inch ASUS monitor, works great. Except starting today there is a faint consistent squealing/static noise that come from the built in speakers. Only happens when the audio cable is plugged in. Tried it with another computer and it didn't do it. Couple people said it may be interferance from phones/wifi but there isn't anything like that near my PC. Which kind of led me to believe it may possibly be a motherboard problem? It's the most annoying thing ever. Any help would be great
Try with other speakers if the whine is still there rma it if you can. If not buy a cheap soundcard.
I just use hdmi, and I also almost never use the speakers on my monitor, as I have a headset.... never had this problem
I don't use a headset that often so I need my speakers :3
But I'm waiting on a HDMI so hopefully that'll solve it
