Hi all.
A little while ago I was doing some work on an old PC that refused to power on (fixed it now, somehow). As I was working on it, the side panel fell, tumbling into my monitor and casing three small scratches.
One bit's fairly deep, the rest is quite shallow.
I've tried using a repair pen on eBay, and £10 down the drain. Didn't work in the slightest.
I've tried the eraser, toothpaste, and vaseline, all coming off when I remove the excess.
From what I've heard, Xerapol is a good scratch remover. Question is, would it fix my issues? I plan on getting a new monitor anyway, but I'd like to replace my 2005 17" 2nd monitor with this one.
Thanks all, it's annoying me to hell and back.
(also, when the monitor is on but showing a blank screen (backlight only), you can see a weird outline around the scratch. but since i'm going to be using it for mostly white apps, it's not a big deal. it's also causing a very annoying rainbow effect.)
