Scary Screw in Power Supply
So I think all PC builders have had this problem but today while I was installing screws into my 7870 ghz edition a screw fell and I didn't know where it had went so I checked my PSU and what do you know there was rattling (sounded like a screw) so I spent an hour trying to get the screw out (took of the fan cover thing) but it never got out and all of a sudden after an hour and a half of stress there was no rattling and NO screw. So yeah I quickly installed it back in and turned it on, it WORKED!? So yeah what do you think of this, should I be concerned as keep in mind I hear no rattling anymore and I'm not completely sure there wasn't even a screw in the bloody thing. Scary.
You should remove the screw from there. That's a sure thing. It can damage your system and... It's a power supply, I'm afraid it's even dangerous. lol
I mean, it's not that hard to disassemble a PSU. IMO it's better to make sure the screw is not there.
Before you answered, I got scared and just pulled all of my cables out and took out the fan grill and shook the PSU for about 10 minutes and then the screw came out. Life lesson learned, don't be impatient. I could of jeopardized a 700£ PC. Thanks for your help!
Just a side note, always be careful when disassembling a PSU.  Those capacitors can take a while to fully discharge (in some it's seconds, others can take minutes).  Better safe than singed.
Same thing happened to me during a graphics card upgrade. I spent half an hour searching for that freakin' screw until I finally got it out. :/
OMG this exact thing hapned to me the screw is still in my psu but their is no rattling, and no malfunctions so dnt be so worried
I got mines out after bashing the shit out of it. I suggest you do the same because what motivated me to try again was what happens when you move your PC and the screw moves and falls on the circuit. Your PC is dead.
