Save My PC [HELP] [CPU USAGE]
Hey my PC set me back 1k and now there is a major issue, the CPU is at 99% load and most of that is due to something called local service system host, I did some research some say it's malware here is a pic
There it is only at 15% but it changes rapidly from 15 to 70 and sometimes higher, I think it is a Malware controlling my computer because sometimes when I launch google chrome for example it tells me that 70% of my CPU power is being taken by chrome but after extensive research I know the true culprit is the local service host I don't know how to fix this I did run a Malware bytes scan (It's still going) and it detected 1 infected file so far, not sure how to resolve that after the scan is done and more info is provided if you solve I will reward you with a 5 dollar steam game of your choice
Please help
Here are some references to look at
http://www.youtube.com/watch?v=AWAzKiDXvb8
http://www.slideshare.net/besttechtips/how-to-fix-svchostexe-high-memory-and-cpu-usage-problem
Ummmm, so Malwarebytes should give you the option to remove the infected file.
Also, are you running a normal 24/7 virus software?
Yeah I am running Norton all the time.
Btw this started happening right after I downloaded Slender on their official website, so you might not want to download that
Here is a pic showing how it shoots up constantly
i like spybot as my maleware scanner. could give it a try to see if it finds anything. if you just build your system i dont think a format would be too out of the question
Yeah malware bytes has been running for over an hour and so far found 1 infected file, wonder how much longer... Once the scan is complete do you know what happens is it gonna tell me how to trouble shoot the infected file or resolve it for me or what?
Btw, this used to happen to me and it just stopped one day, and I tried restoring the computer to factory settings and that did not fix anything.
Help
what version of windows are you on? i may be able to help :3
man, just format and reinstall your os
Windows 8, please help and restoring does not fix anything @anarekist
Have you tried that? if you have hit me up on skype @ xexax2 ill try to help
Malwarebytes detected and removed one threat, that didn't fix anything
could you use gyazo to upload a screenshot inside task manager so i can see what is causing it (make sure you also expand the process)
The process hogging my CPU is constantly changing by the way
have you refreshed windows? on the metro settings area? and if you have go to msconfig, and disable some of the services which arnt usefull
Can you tell me in a little more detail, idk what you mean by refresh windows or msconfig sorry
ok, open up the charms, then hit settings, then hit pc settings, navigate to general, and find the refresh windows, then hit get started and its easy enough from there. if u need more help just add me on skype its easy to communicate a lot quicker XD
Whtas your skype
xexax2
