I’ll have symmetric gig (hello, game hosting) and I intend to make the most out of it.
My place is 2 story, ~2000sqft and I intend to put the NOC in the centrally located laundry room, given it’s convenient proximity and whatnot. Unfortunately, there’s no structured wiring at the moment, but I’m considering doing that in the future. For now, I think I’ll just aim for a single stronk AP.
I’m extremely out of practice with subnetting and whatnot, so at this point, I’m looking for recommendations for how you’d split the networks up if it were your house, and what address space the nets will take up.
Dual stack. Don’t drop ipv4. It’s needed for some fall over. Did you want to be able to access Newegg or anything without it? Because there’s a lot of sites that are still ip4 that are popular… as ridiculous and stupid as that is
Not gonna lie the new mesh stuff is super nice. You always have ubnt and micotik
Velop and Orbit come to mind as does Google Wifi. Wi-Fi doesn’t need to be tweaked and don’t let your authors and get the better of you. Enjoy convenience
Home should be a break from work and you shouldn’t have to come home and do IT work because you just spent all day doing IT work. Let’s be real
My unifi ap wifi 6 has been great (works as a night light as well) and I currently have four SSID 's out of it. Run the controller as a container on the NAS.
Unforseen pro: Night light action (low light mode on cam so it appears brighter than it really is)
IMO run cable as much as possible. I bit the bullet both ego and wallet and hired an outfit all day to run Ethernet to a lot of spots all running back to a closet I use as my network center (pfsense, PoE switch, 16 port ‘smart’ (vlans) switch.
Fast forward and it’s been awesome having wired Ethernet in various rooms and the garage.
@SgtAwesomesauce You are in SD right? I will be there Labor Day weekend. If you help me run the wires in your place I’ll cut you a deal on labor. PM me if you want.
Its open source and quite configurable in any manner but its like the arch linux of router software. You might like this. Id choose the UniFi AP 6 LR or the TP-Link EAP615-Wall v1. They are both conveniently wall mountable. Easy to wire away. Also the TP-Link is much more well equipped for the firmware on snapshot and has the better radio but the ubiquitin has the more powerful processor and better antenna array to handle 4x4 MIMO but again you are a single dude maybe looking at second person max… for the foreseeable lifetime of the device so its up to you.
Single AP wired into your protectli. Is quite simple. I know how your network is constructed ATM. This would not be too hard and would net you the performance you desire.
Just as a personal experience note, I set my Netgear open WRT router… the nighthawk AC2400 (w/4 antennae) … The first time I got it. I have never even so much as visited it’s interface or ssh ever again. It’s been true set and forget in dumb AP mode routed to my protectli. I just have an ap isolated guest wireless network with a different subnet and I tell opnsense not to allow that network to talk to others … I completely forgot how I set that up LMAO. That’s how set and forget it was for me.
@SgtAwesomesauce I highly recommend getting off common subnets like 192.168.1.0/24 to avoid routing problems when using VPN, etc. There’s plenty of IP space in 192.168.0.0/16 that isn’t commonly used.
He has a opnsense firewall based on the coreboot power protectli and has extensive networking experience I doubt this will be too much of an issue.
That said I use class B 10.31.xx.yy and just subnet by changing the xx and I have no issues and even some of my vpns run on that. Routing isnt too bad when you have a good firewall router like opnsense but that’s my personal experience it could be different for some.
The kicker is I can cover 2000 sqtft up and down with a single router with good placement haha. So it’s small in my personal perspective lmao
Perfect. I’ve been trying to get away from the ubiquiti management interface to go to something more… Free.
Moving to Temecula, actually. But ill DM you.
I mean as far as wireless coverage goes. I’m coming from a 3600sqft place in the sticks, that was single story and had a lot of metal for interference. (Rented that place with two other dudes)
These houses… Maybe 20 feet between them.
The numbers aren’t set in stone, just throwing out suggestions for sizing.
Most businesses slice up a /24 from the 10 block these days for vpn, from what i can tell.
Will check.
Yeah, that’s staying, i think. My roommate wants to buy most of the network gear because it just works. He knows enough to figure it out.
I would definitely put open WRT on the TP-Link I just mentioned then and hook it directly into opn sense cuz that’ll be a flawless setup. I have had no issues. It’s been a very reliable setup.
If you want lots of APs. The Belkin RT3200s have been reportedly extremely solid by many SNB forum users using openwrt. This is rapidly developing as well. Just a few months back none of this was stable
That was true about 3 months ago. It’s changed a lot as is the nature of something that’s being newly supported
There’s now a stable build. It literally says so in my link that I gave. It’s just a matter of following their instructions properly and configuring it properly. There’s a lot of options in 80211.AX that people want to mess with, but they really shouldn’t do that. That’s where most of the strange wireless behavior stands for. As for the rest of the system, most of that’s okay, especially the routing part and the switch part and changing the functionality from managed to dumb AP.
I have a very small space for VPN in the 172 RFC 1918.
What VPN are you looking at?
I have an OpenVPN setup but I didn’t have a warm fuzzy on split tunnel for full time phone and
travel connection so I broke down and setup tailscale for a very long upcoming set of travel.
Tailscale is everything it says it is… but its a 3rd party that has a tunnel ability into your NAT…
If you are referring to the dude who bricked his interface testing a “snapshot” build there’s not enough information there to ascertain if that was user error or their firmware.
The most I saw is exactly 1 users testimonial that it went in recovery mode and reporting a bug (which is good to see. Bug reports are good/. And you know what. This is @SgtAwesomesauce we are talking about. He’s a dev. He knows how to handle these issues. I’d like not to have to scroll through 2000 posts. Exact issues would be helpful
