I am wondering which GPU would be better for playing games such as Battlefield, COD, Minecraft, and Crisis 3.
If you have any suggestions PLEASE comment them below.
Look up some benchmark comparisons for the two cards but, as far as I can remember, the 680 preforms better overall but the 7970 gives you more bang for your buck. Still, I would look up some benchmark comparisons between the two cards but if you have a large budget for your GPU, definently go GTX 680.
Huh?
Unless you plan to also do some editing with software that takes advantage of cuda cores then get the 7970.
