Having a hard time deciding..
Strictly gaming.
WAAADDAAPP?
Strictly gaming.
WAAADDAAPP?
Go the 7950. It should out-perform the 660ti in most cases.
7950 will beat it. The 7870/7870 xt is in the same ball park as the 660ti.
7950 OC'd is comparable to/greater than 770/7970 performance.
Get the 7950. If it is the Vapor-X version, even better!
DirectCU II beats Sapphire Dual-X normally though. The 660 Ti in gaming is slower than the 7950.
What ever one is cheaper the 7950 is going to be better but the 660ti is still a good card
7950
literally a new topic about this posted everyday (although usually it's 7950 vs 760)
yep
I think we need a stickied faq with a leaderboard showing the best cards for the best resolutions
e.g
1080 p
1...
2...
1440p
1...
2...
If there was also a realtime aspect built into it for pricing (and links to affiliate deals so tek benefits) then it would be awesome
