I currently have a GeForce 760 TwinFrozr edition GPU with 2GB of GDDR5. I was wondering, since my 1440p monitor is coming this Tuesday whether an r9 290 stock 4gb would be a good choice and would be able to run some heavy games at that resolution. I can get it for 216 dollars 2nd hand, would that be a good price?
I've ran Battlefield 4 very well at 1440p with my R9-290. Some newer games can be more taxing, but there are options to tweak anyhow. Something to remember about the stock R9-290 cards using a single centrifugal fan is that they will be very loud when the card is pushed. Using some tweaking software can help a lot to keep the noise down during lighter loads, by setting a custom fan curve. But high load will remain very loud.
Unfortunately the options are very limited in my country. Is the loudness of the fan the only issue? There are currently no 2nd hand video cards for this price that arent r9 290 (with the exception of other 2gb cards but i want 4gb)
Yea, it gets extremely loud. You can pump up the reference (stock) cooler fan with something like MSI Afterburner to cool the GPU fine, but it's going to sound like a jet engine in your case. If you're okay with that, go for it.
Where do you live ? If you count in euros , you should be able to order from where I am ; france , germany or belgium , R9 290's go for about 180-220€ .
If you can trade up for only 20€ extra , DO IT , you can add an aftermarket cooler with the remaining budget .
You can also just look on ebay for a 290 if you want to , but I do think the trading up is the best option .
BTW all I need is your address if you want me to ship the VRM coolers to you .
Also , if you want to get a card new , caseking has a 290 for 230€ http://www.caseking.de/shop/catalog/Christmas-comes-early-this-year-Weihnachtsangebote:_:1134.html
